Position options
This really doesn't explain the difference between the two.
The default is Projected tolerance zone and is equal to the length/depth of the cylinder, which is what I would consider "normal" or the "standard". I understand if the drawing calls for a projected tolerance zone beyond the considered feature, that this must be additionally defined.
Maybe my question should have been what does it mean by "calculation of centerline"?
Is this an ISO vs AMSE issue?
I am fairly sure its the same idea as perpendicularity of a cylinder, ASME vs ISO
ASME uses the (P) button as it uses the axis of the cylinder, calculated based on whatever evaluation setting you choose ( Technically should be OTE but that's a different discussion). But this does let you use a Projected Tolerance zone like mentioned if it applies, but otherwise the zone defaults to the length of the Cylinder, perpendicularity works the same way.
ISO uses the Derived Median Line (Cylinder with Form). And I would guess that if an ISO drawing wanted a projected tolerance zone there would be modifiers on the drawing that tell you how to change the evaluation method to satisfy the requirement.
I think that on the left is real length of scanned feature and (P) is used as defined nominal or if drawing define it.
It works like you scan a thread, but it will not give you info about assembly, so you prolong that TP to place where you have bolt head for example.
Are you guys saying that when selecting the Projected tolerance zone, it is following the ASME methodology? Seems to me, the P option is strictly for creating an evaluation outside of the feature's own geometry but still using a derived median line. I don't believe Calypso has ever considered the ASME methodology in any setting, until 2023 when using the beta system maybe. Am I wrong?
That's exactly what I'm saying. P uses the calculated axis defaulted to the length of the cylinder, NOT derived median line, so AMSE compliant. The Cylinder with form option uses the Derived median line, which is ISO.
It's in the cookbook like that too with a basic explanation.
If Zeiss wanted to make it less confusing they would name is better, P can be used to project the tolerance zone, but it doesn't have to.
I'm not buying it. Especially due to the topic of applying a projected tolerance zone in ISO. However, since I haven't seen a cookbook since 2018, I don't know what it shows now. I agree, why would you add the confusion of using the P icon option for a position that didn't need a projected tolerance zone? Since it is the default setting, most people probably don't even notice until they have a call out on the drawing. Does everyone that uses ISO automatically click the derived median line icon? If it was meant to be a differentiation between ISO and ASME, identify it as such. Leave the P icon for the calculation of an actual projected tolerance zone, regardless of the evaluation.
I am keeping (P) check since it will check for nominal length of a cylinder ( i scan 2mm from edge, sometimes you can not scan whole length )
  • 2 weeks later...
