Using features from Calypso and GearPro for measurement
Hello all. I have a question regarding the use of both GearPro and Calypso at the same time. I am wondering if we would be able to use GearPro to get a minor diameter on an internal spline and then use Calypso to call that measurement to use for a concentricity measurement to the outer pitch diameter of the part. Is there a way to do this?
  • 3 months later...
Chris,
Thank you for the information. Can you tell me where you would recall this information? We were able to output the information in ASCII but are wondering how we would bring it in to the measurement plan in Calypso. Thank you.
Here you go.
If you set it to the right directory in Gear Pro and leave standard file name, it should pull this new file in Calypso for every gear run. 3239_03fb3fb0f6b22925fe5548eb6ae58218.jpg
Tip : if circle Dia looks strange you may want to deactivate probe comp in evaluation.
Good luck.
Chris
