[Ja...] Posted May 28 Share Posted May 28 Hello all. I have a question regarding the use of both GearPro and Calypso at the same time. I am wondering if we would be able to use GearPro to get a minor diameter on an internal spline and then use Calypso to call that measurement to use for a concentricity measurement to the outer pitch diameter of the part. Is there a way to do this? Link to comment Share on other sites More sharing options...
[Ch...] Posted May 28 Share Posted May 28 yes output ASCII points from GP, recall points from file in Calypso. Link to comment Share on other sites More sharing options...
[Ja...] Posted September 20 Author Share Posted September 20 Chris, Thank you for the information. Can you tell me where you would recall this information? We were able to output the information in ASCII but are wondering how we would bring it in to the measurement plan in Calypso. Thank you. Link to comment Share on other sites More sharing options...
[Ch...] Posted September 20 Share Posted September 20 Here you go. If you set it to the right directory in Gear Pro and leave standard file name, it should pull this new file in Calypso for every gear run. Tip : if circle Dia looks strange you may want to deactivate probe comp in evaluation. Good luck. Chris Link to comment Share on other sites More sharing options...
