Live results
Is Calypso capable of displaying live results? I have a program that is measuring a calibration tester and there are many programmable stops and manual adjustments that are made during the program. The scale on the tester is manually adjusted for every feature (it climbs in Z+). It would be nice to know live results. Otherwise, a bad manual turn of the calibration scale won't be revealed until the entire pgm is complete and it would have to be restarted. Thanks!
Contura 9/12/8
Vast XT Gold
Calypso 2021
Yes, that worked...kind of. I was hoping that the Characteristic tab features would turn green/red instead of having the report in the background. Better than nothing, though! Thanks!
This is possible but for this you would need change your inspection plan pre-settings for "Order of Run" to "From Characteristic List". Typical run order is "From Feature List" and is usually more efficient.
Be aware that this WILL affect the run order of your inspection plan so ensure your navigation paths/settings are robust and you may need to adjust some list ordering to optimize efficiency.
  • Like! 1
