Universal Project Template
I'm not sure if this is possible or if this would cause any issues, but is it possible to have a generic/universal export script that runs the inspection, and exports the report/ csv to the parent folder? As if it were a project template being run through kiosk. We only utilizing the scanbox for product scanning.
Hello Zach Ward,
yes this is possible. For this you could use the recording feature of the script editor. Basically every command in the Software can be recorded by this. If you have a sample project you could record all the inspections done manually and use this recording for the follow up projects.
Regards,
Daniel Schrein
