[c2...] Posted September 12, 2024 Share Posted September 12, 2024 I've successfully completed and ran my GearPro [2022] program calling it from Calypso. Now my print calls for True Position of the Pitch Circle to the Datums I have programmed in Calypso. Besides remeasuring or approximating the Pitch Circle in Calypso using several Self-Centering points and recalling to Circle, is there any way to use my GearPro programming to report this True Position. [I know I can add Fr - Radial runout to the GearPro report, but it's not quite the same.] Thank you, Link to comment Share on other sites More sharing options...
[Ch...] Posted September 12, 2024 Share Posted September 12, 2024 I have requested this be added to Gear Pro, you can export points from Gear Pro (ASCII), then in a circle in Calypso you can read points from this file. Good luck. Link to comment Share on other sites More sharing options...
[c2...] Posted November 12, 2024 Share Posted November 12, 2024 This worked great. Thank you Chris. Link to comment Share on other sites More sharing options...
