[Lu...] Posted September 10, 2024 Share Posted September 10, 2024 Hello, I would like to ask you for help with the evaluation of the profile with two datums (Datum A - Plane, Datum C - Cylinder) How to ensure that all ISO/ASME rules will be followed? How to set up the datums in evaluation? 1. ISO base system 2. ASME base system. Have to be ticked normal vector in Datum C? Thank you for our help LukasDatum C.JPGDatum A.JPGBase system.jpg Link to comment Share on other sites More sharing options...
[Ma...] Posted September 11, 2024 Share Posted September 11, 2024 I don't know exactly how to set up callout with two datums correctly the way you did, so i would approach differently. Create alignment with "plane" as rotation in space ( "primární" ) Leave blank plane rotation ( "sekundární" ) Fill XYZ as needed with intersection with plane and cylinder Then make alignment from many curves. Here set base alignment to previously created one, fill your curve/s and allow ( check ) only rotation in one axis ( as defined in previously created alignment ) Now you can evaluate to this new curvy alignment. ISO and ASME would only apply in Gauss and Tangential evaluation method ( at least i think ). Link to comment Share on other sites More sharing options...
[Ma...] Posted September 12, 2024 Share Posted September 12, 2024 Summoning some ASME users Please sign in to view this quote. Please sign in to view this quote. Please sign in to view this quote. Author would like to know how to correctly implement ASME norm - cylinder perpendicular to a plane. Thanks Link to comment Share on other sites More sharing options...
