[Se...] Posted June 15, 2024 Share Posted June 15, 2024 Hello. Please, does anyone know what format a txt file must have to import points in Calypso? Does anyone have an example? Thanks in advance. Link to comment Share on other sites More sharing options...
[Ma...] Posted June 16, 2024 Share Posted June 16, 2024 It should be numbers with space between as "X Y Z" or with addition of vectors. You can try to save points - then you will see what options you have and it's format. Link to comment Share on other sites More sharing options...
[Se...] Posted June 16, 2024 Author Share Posted June 16, 2024 Hello Martin. I will try. Thanks. Link to comment Share on other sites More sharing options...
[Mi...] Posted June 17, 2024 Share Posted June 17, 2024 Hello Sergio. file extension: txt format coordinate in row: x, y, z Link to comment Share on other sites More sharing options...
[Za...] Posted September 11, 2024 Share Posted September 11, 2024 CALYPSO uses whitespace as delimiters in the point files for information about the point. Either spaces or tabs will work for the file, but other formats will not work. Newlines are used to delimit between individual points. For importing measured data, CALYPSO will accept either six or seven entries per row. The first six entries are, in order, the x position, y position, z position, x normal vector component, y normal vector component and z normal vector component. The optional seventh is a radius, and CALYPSO will automatically move the point by that much in the direction against the normal vector. If no radius is given, it is treated as 0. For importing nominal points, only the first 6 are necessary. The above is an excerpt from: https://portal.zeiss.com/knowledge-base?id=1224400 the below article may also be of service: https://portal.zeiss.com/knowledge-base?id=445483 Link to comment Share on other sites More sharing options...
