Calypso. Import points with txt file.
Hello.
Please, does anyone know what format a txt file must have to import points in Calypso? Does anyone have an example?
Thanks in advance.
It should be numbers with space between as "X Y Z" or with addition of vectors.
You can try to save points - then you will see what options you have and it's format.
  • 2 months later...
CALYPSO uses whitespace as delimiters in the point files for information about the point. Either spaces or tabs will work for the file, but other formats will not work. Newlines are used to delimit between individual points.
For importing measured data, CALYPSO will accept either six or seven entries per row. The first six entries are, in order, the x position, y position, z position, x normal vector component, y normal vector component and z normal vector component. The optional seventh is a radius, and CALYPSO will automatically move the point by that much in the direction against the normal vector. If no radius is given, it is treated as 0. For importing nominal points, only the first 6 are necessary.
The above is an excerpt from:
https://portal.zeiss.com/knowledge-base?id=1224400
the below article may also be of service:
https://portal.zeiss.com/knowledge-base?id=445483
