Start Parameter is Not Defined in the Autorun
Could someone take a look at the alarm I attached and give me some idea as to why this is happening?
I created the Start Alignment in the same way I always have, and ran it in the programming side of Calypso without any problems. For some reason, I cannot get the program to run in AutoRun.
Any help is greatly appreciated!
P.S.-The program name is blurred for security reasons.
I've run into issues occasionally when I change the alignment of a program after it's been out in auto run... Even if I go into the Define Run Parameters and select the correct alignment the issue persists... Usually deleting it then recreating it in Auto run is the fix.
When I think "Run Parameters" it leads me to think of the run window values and CALYPSO/AutoRun seems to be stating something about the alignment... I'm sure you have looked this over in AutoRun already but does anything look out of place in the Run Window?
Maybe you can post a picture of yours? 822_4e80c2269ba99ded411c137c8a203f9b.png
The warning message appears when the base alignment of an Autorun icon is missing completely:
Something that normally shouldn't happen as the selection is by dropdown and you can't leave it empty intentionally.
I couldn't find a program with a start alignment offhand, so I don't know what happens when that one is missing.
You may want to load the *.arn file in a text editor and check if the following portion is present for the program in question:
add: (#coordsystem -> '<name_of_your_base_alignment>'); yourself)
