Profile Constraint.
I have a cylindrical part (imagine a tall thin wine glass). The stem is the datum (-A-) and the inside glass (bowl) has a surface profile callout back to -A-. The datum and bowl run along the Y axis. Do I create a Best Fit inside the FFS allowing only rotation around the Y axis, create an alignment (WP_Free Form Surface1) referencing that inside my Datum -A- secondary alignment?
If from drawing can be determined, that only datum for callout is "profile" axis, then you can use translation in axis too.
Any sketch describing drawing would help with solution.
OK so in this case make an alignment where will be as main this A cylinder.
Then your FF will have this alignment - then you can check only rotation in Y and translation in Y - nothing more.
Checked is allowed.
Because of A gives you an axis, so you can only rotate ( depending on shape it will or not give you better number ) and movement along its axis.
Yes. For FF it's the only way, but i would rather use curves and align from many curves ( if you create FF with scanning path, then you can recall points with recalculation into curve ( remember to delete actuals before recalculation ).
On curves you can choose points which will go into calculation, aka mask points.
