[Cl...] Posted August 29 Share Posted August 29 I have a cylindrical part (imagine a tall thin wine glass). The stem is the datum (-A-) and the inside glass (bowl) has a surface profile callout back to -A-. The datum and bowl run along the Y axis. Do I create a Best Fit inside the FFS allowing only rotation around the Y axis, create an alignment (WP_Free Form Surface1) referencing that inside my Datum -A- secondary alignment? Link to comment Share on other sites More sharing options...
[Ma...] Posted August 29 Share Posted August 29 If from drawing can be determined, that only datum for callout is "profile" axis, then you can use translation in axis too. Any sketch describing drawing would help with solution. Link to comment Share on other sites More sharing options...
[Cl...] Posted August 29 Author Share Posted August 29 Unchecked activates? See PDF Link to comment Share on other sites More sharing options...
[Ma...] Posted August 29 Share Posted August 29 OK so in this case make an alignment where will be as main this A cylinder. Then your FF will have this alignment - then you can check only rotation in Y and translation in Y - nothing more. Checked is allowed. Because of A gives you an axis, so you can only rotate ( depending on shape it will or not give you better number ) and movement along its axis. Link to comment Share on other sites More sharing options...
[Cl...] Posted August 29 Author Share Posted August 29 Please sign in to view this quote. Got it. Thanks Martin! In my 20+ years I have never had to use this. Link to comment Share on other sites More sharing options...
[Cl...] Posted September 6 Author Share Posted September 6 Please sign in to view this quote. Ok, so I check only what I want to rotate & translate (Y). Then do I click "Create Alignment" button? Link to comment Share on other sites More sharing options...
[Ma...] Posted September 6 Share Posted September 6 Please sign in to view this quote. Yes. For FF it's the only way, but i would rather use curves and align from many curves ( if you create FF with scanning path, then you can recall points with recalculation into curve ( remember to delete actuals before recalculation ). On curves you can choose points which will go into calculation, aka mask points. Link to comment Share on other sites More sharing options...
