Rotary table from autorun
Hello. Is it possible to rotate rotary table from the AutoRun menu ?
Majority of my programs using roatry table only as a fixture (passive) so I need to roatate the table manually before I load the part.
It's been a little while, but the only way I know is that if you run a program that uses RT it will open the RT dialogue box when it starts. You can then stop this program, and the window will stay open (no need to every close it). You can rotate the rotary from that screen.
If you want to do it the manual way, just press down on the top of the Z joystick, hold it down, and move it left or right - it will rotate the RT for you manually.
  • 4 weeks later...
Yes, but this is not for me. This is for cnc operators where we need to treat them like people without brain. Sorry about this but trust me some of them do not have it. I could not find any other option which is shame.
  • 5 years later...
Were you able to figure something out? We are arriving at the same problem where we need to set the Rotary table in load/unload state for the operators to change fixtures while in the Autorun screen.
I haven't been able to find anything yet.
