[Ra...] Posted December 7, 2023 Share Posted December 7, 2023 Just a week ago we were able to run autorun and it would keep the multiple reports windows on the desktop to save. Now we have a issue where it closes out last report and leaves open the new one , so on. Ive tried changing result destination path and the files that get saved are .chr .fet . hdt . Whats the best way to have the results saved into a desired folder destination and we need it to be excel not chr fet hdt. Thank you. Link to comment Share on other sites More sharing options...
[An...] Posted September 3 Share Posted September 3 Excel is tricky with CALYPSO. The only way to control where the excel file goes is by changing the global directory location as shown in step one of this article: https://portal.zeiss.com/knowledge-base?id=587888 The only other way to auto assign where an excel goes outside of the default directory is to use a third party option like a batch file is most common. Here is a list of batch file names, if you name specifically it will execute automatically in the program accordingly. But it is up to the user to create the actual script inside the batch file to do what you want. I typically just use google to figure that part out. https://portal.zeiss.com/knowledge-base?id=522725 Link to comment Share on other sites More sharing options...
