Colorcomparison (point set) overview
Hi.
I struggle a bit with a solution which can give me a good overview for a colorcomparison on different cavities and samples with different moulding process.
My wish are to create a PiWeb report which shows a specific view from the colorcomparison (Point Set -> Create graphic). So if I have 4 different graphic views in my characteristics, then I can select view 2 and get a report which contain view 2 for all the selected cavities.
The reason for this is that I wan't to be able to deliver a fast and easy overview to compare the difference (if any) on the cavities in the mould, instead of open up a single report from each cavity. Of course a big benefit would be, that I can set the wanted size of the view in the report, and then it automatic expand to the needed pages.
Hope it make sense, and that it's possible.
I have PiWeb Report Plus and CALYPSO available for the task.
  • 5 months later...
