Profile of Circle
So I am tasked with finding Surface profile of a circle. We have a new Eng and he loves profiles lol. I have a bore that has a Diam Of 22mm and Depth of 7mm. He has added a surface profile call out of 0.1 to this ID. Never had to do it this way. Need guidance lol.
Do I go in, kick off some circles that I can flood with points then recall those points into a profile of a surface somehow? He wants the profile results from circles inside the Diam. Kinda scratching my head.
Is there a Datum feature called out?
I think a "Surface Profile" would need to apply to a Cylinder of multiple circle paths... I think a single Circle would need to be recalled in a Curve, for a Line profile(?).
I'd section the model (assuming you have one) several places down into the cylinder and
extract curves, recalling them into a FFS. You can't do surface profile on a 2d feature (circle).
With that and resticting ( locking ) coordinates and radius you can achieve same thing and profile - but i think it will be without doubling value.
If the size is perfect, the roundness (minimum error fit) of a circle is equal to the profile, because the plus and minus radial deviations are equal and summed for the result. If the size is not exact, the min or max radial deviation farthest from the nominal radius is doubled to determine the profile.
