Open Favorite Programs
I accidentally checked the box "do not show favorites again," and now I don't know how to undo it. Can someone please help me turn on favorites again?
Hi,
aus einem anderen Beitrag:
C:\Users\User (unter dem der Haken gelöscht wurde)\AppData\Local\Carl_Zeiss_Industrielle_M
Den Ordner der unter dem Carl_Zeiss_Industrielle_M liegt löschen, dann sollte der Haken wieder gesetzt sein. Die Einstellung ist User bezogen.
viewtopic.php?p=53318#p53318
Thank you. I changed the "classic" value in the user config to "false". It worked. Do you know if this will this affect any other user settings?
Sounds like you figured out a method but here is the alternative: If one would like to disable the window you can “Right Click” > Don’t show favorites again. To undo this setting delete the CALYPSOFileDialog.exe folder located at C:\Users\<USERNAME>\AppData\Local\Carl_ZEISS_Industrielle_M.
This can be found in the CALYPSO: Open Measurement Plan Tutorial: %5Bcolor=#0000FF%5Dhttps%3A//portal.zeiss.com/knowledge-base?id=1444152%5B/color%5D
