[Lu...] Posted August 22 Share Posted August 22 I accidentally checked the box "do not show favorites again," and now I don't know how to undo it. Can someone please help me turn on favorites again? Link to comment Share on other sites More sharing options...
[Se...] Posted August 22 Share Posted August 22 Hi, aus einem anderen Beitrag: C:\Users\User (unter dem der Haken gelöscht wurde)\AppData\Local\Carl_Zeiss_Industrielle_M Den Ordner der unter dem Carl_Zeiss_Industrielle_M liegt löschen, dann sollte der Haken wieder gesetzt sein. Die Einstellung ist User bezogen. viewtopic.php?p=53318#p53318 Link to comment Share on other sites More sharing options...
[Lu...] Posted August 22 Author Share Posted August 22 Thank you. I changed the "classic" value in the user config to "false". It worked. Do you know if this will this affect any other user settings? Link to comment Share on other sites More sharing options...
[Se...] Posted August 23 Share Posted August 23 Sollte es nicht, da es immer Benutzerbezogen ist. Link to comment Share on other sites More sharing options...
[Ch...] Posted August 28 Share Posted August 28 Sounds like you figured out a method but here is the alternative: If one would like to disable the window you can “Right Click” > Don’t show favorites again. To undo this setting delete the CALYPSOFileDialog.exe folder located at C:\Users\<USERNAME>\AppData\Local\Carl_ZEISS_Industrielle_M. This can be found in the CALYPSO: Open Measurement Plan Tutorial: %5Bcolor=#0000FF%5Dhttps%3A//portal.zeiss.com/knowledge-base?id=1444152%5B/color%5D Link to comment Share on other sites More sharing options...
