See Results (Red/Green) Characteristics While Running
Is there any way to have the characteristics populate while the program runs? At least knowing if the characteristics are red or green be a big help.
What he said, run from Characteristics list.
Drawback is the efficiency of your program will likely suffer. You absolutely can make a program run as fast, but it will take careful organization of the Characteristics list to do that. The longer the program the harder that will be, much harder than making an efficient program that runs from Feature List. The Characteristics list being organized for machine efficiency will likely be very unintuitive for the people who have to read the report as well.
And if you do it once, people will expect it because it would be a nice thing sometimes... be ready to put that work in to all your programs before you show people you can do it.
Thank you. Sorry, I thought I had already tried running from characteristic side, but I must be mistaken. I'll try it again on a short program. However, it doesn't seem worth all that work if it's just telling me "red" or "green". It's probably easier to just stop the program halfway through and run subsequent evaluation.
