Performance Calypso 2024
Hallo,
Ich habe sehr lange Berechnungszeiten bei 3D bzw 2D Einpassungen.
Calypso 2024 sollte ja auf 64Bit laufen und somit schneller sein.
Hat noch wer so hohe Performance Einbußen?
I don't think that architecture have anything to do with calculations speeds. It only limits memory usage, so on 64bit application you can use more RAM.
I believe on 32bit system you could not exceed 2GB allocated RAM on one process/application.
As far as i know, Calypso is not using many threads ( i think max 3 or 4 ) so only limitation would be GHz on procesor, speed of RAM sticks and storage speed.
Not sure how it's on AMD, but on Intels you can force process to be on performance core.
For storage should be enough read/write speed up to 1,5GB/S - anything above won't bring better performance.
RAMs can be tricky on AMD - check EXPO if available.
