7.6 To 7.8
So, I just completed the upgrade. Like to know if there is a way to make calypso copy over the files to 7.8. I know there is pop up window that asks this when you run it for the initial set up BUT somehow, I clicked off that and now its gone lol.
Is there a way to bring that copy feature pop up window back? I know I can copy the folders/files, but rather the software do it. Its a lot of files yadda yadda yadda
Mike
There might be another way, but I believe you can just delete the config folder for 7.8, and then it should prompt you again when you open Calypso again.
Please make sure you delete the right config folder. 🙂
You can also use the Save/Restore Function in Extras - Settings - Miscellaneous - System.
