[Mi...] Posted August 27 Share Posted August 27 So, I just completed the upgrade. Like to know if there is a way to make calypso copy over the files to 7.8. I know there is pop up window that asks this when you run it for the initial set up BUT somehow, I clicked off that and now its gone lol. Is there a way to bring that copy feature pop up window back? I know I can copy the folders/files, but rather the software do it. Its a lot of files yadda yadda yadda Mike Link to comment Share on other sites More sharing options...
[Ri...] Posted August 27 Share Posted August 27 There might be another way, but I believe you can just delete the config folder for 7.8, and then it should prompt you again when you open Calypso again. Please make sure you delete the right config folder. 🙂 You can also use the Save/Restore Function in Extras - Settings - Miscellaneous - System. Link to comment Share on other sites More sharing options...
[Mi...] Posted August 27 Author Share Posted August 27 Ill give it a shot Link to comment Share on other sites More sharing options...
[Ab...] Posted August 27 Share Posted August 27 Hello Here is a knowledge base article on backup and restoring https://portal.zeiss.com/knowledge-base?id=444235 Link to comment Share on other sites More sharing options...
[No...] Posted August 28 Share Posted August 28 Please sign in to view this quote. To get that window back, you need to edit a config file: viewtopic.php?p=32650#p32650 Ignore section 1.) You only need section 2.) Link to comment Share on other sites More sharing options...
