Merge File Location?
Hello,
I'm currently running 16 identical parts (5 characteristics each) and using Name for Output Files>For This Measurement Plan>Characteristics Table File>Name of output file variable
Creating a <incremetalpart#>.txt (Ex. 1.txt 2.txt, 3.txt etc)
I would like to have all 16 parts in one text file
I currently have Result to File>Table File and Merge File both checked on.
I can't seem to find where the merge file is saving? I checked Calypso 7.6>workarea>results and its empty. Not saving in the custom location folder either. Not sure if I'm missing something?
Thanks
JP
Also, if you have already created the set of merge files, be aware that clicking the initialize button again, will overwrite the original files with a new, blank set of files, thus deleting the data contained in them. Either move the current merge files to another "safe" location or rename the merge files, i.e. merge_chr.txt to merge_chr_08-22-24
