[Cl...] Posted November 8, 2024 Share Posted November 8, 2024 I know the definition MMC and what it does. I think I know what MMB is. The datum is allowed to shift (move) withing it's envelope of tolerance. Is this correct? Link to comment Share on other sites More sharing options...
[Ti...] Posted November 10, 2024 Share Posted November 10, 2024 Yes, basically you are correct. This example should help. You have a car rotor below. The 5 holes are located from the center hole(Datum A) in a dashed diameter basic callout on the print. And they should be all separated from each other by a 72 deg basic callout on the print. Now imagine you are slipping this rotor over a center boss with 5 bolts coming out. The larger you make the rotor Datum A the more you can jiggle the rotor around until it slips over the 5 bolts. It is in your best interest to make this rotor Datum A as far from MMC as possible so you can move the rotor around more until it fits. If you are measuring these bolt holes on the rotor on a CMM or something know that you need to measure all the holes as a patten when using datum shift b/c you only get one Datum shift not 5 individual datum shifts to make the location of the 5 holes as good as possible... Link to comment Share on other sites More sharing options...
[Cl...] Posted November 18, 2024 Author Share Posted November 18, 2024 Thanks! Link to comment Share on other sites More sharing options...
[Je...] Posted November 19, 2024 Share Posted November 19, 2024 Tim, Thank you for providing one of the most direct and understandable explanations of MMB that I have encountered. Great job. 👌 Link to comment Share on other sites More sharing options...
[To...] Posted November 19, 2024 Share Posted November 19, 2024 (edited) This video also does a good job explaining datum shift. Thank you Don Day. Edited November 19, 2024 Link to comment Share on other sites More sharing options...
[Cl...] Posted Tuesday at 11:05 AM Author Share Posted Tuesday at 11:05 AM I have a true position callout Position .002 M B M (2x .052/.054). Does Calypso use datum shift here or apply the bonus from the feature and the datum? Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 11:23 AM Share Posted Tuesday at 11:23 AM If a datum B is two cylinders/circles, then it should do combination of allowed movement. Or i don't understand your setup Link to comment Share on other sites More sharing options...
[Cl...] Posted Tuesday at 11:47 AM Author Share Posted Tuesday at 11:47 AM Datum -B- is a cylinder. The programmer entered a formula to calculate bonus for -B-. What I want to know, is that correct? Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 11:56 AM Share Posted Tuesday at 11:56 AM Then MMB ( which is on datum B ) is allowed to move within it's tolerance - no other feature is comming into a play. Then there is MMC, which is allowed expand of callout's feature/s tolerance. In other words - you will see possible change in tolerance size only for MMC ( feature ) and not for MMB ( datum ) Link to comment Share on other sites More sharing options...
[Cl...] Posted Tuesday at 12:01 PM Author Share Posted Tuesday at 12:01 PM Got it. Thank you, Martin! 1 Link to comment Share on other sites More sharing options...
