[Su...] Posted August 19, 2024 Share Posted August 19, 2024 I am having trouble with the TP results, getting a +tol of 1005.46mm. How do I construct Datum-B-? Should I trust the 10.30mm results? See attached rough draft. Link to comment Share on other sites More sharing options...
[Ma...] Posted August 19, 2024 Share Posted August 19, 2024 Use best-fit bore pattern on 3 holes for Datum B allowing rotation and translation, then use best-fit bore pattern for the larger hole referencing |A| Primary and best-fit |B| secondary without allowing either rotation or translation but using MMC and MMB Link to comment Share on other sites More sharing options...
[Su...] Posted August 20, 2024 Author Share Posted August 20, 2024 Thanks for responding! Datum-A- is a plane that Z origin is aligned, X and Y origin to the Bolt Circle for base alignment. FCF is the dimensioned hole center 6.4MMC to the -A- plane and -B-MMC of 3x holes. I attached the settings I used. Link to comment Share on other sites More sharing options...
