PCM ERROR
Hello, everyone.
An error occurred while using PCM.
Let me show you two things.
1. PCM currently in use
ID = getActual("Sphre PALPEUR REF").diameter
//Diameter
//Lower Tolerance
if ID <29.98871 then
display(getActual("Sphre PALPEUR REF").diameter)
message("Clean Probe")
status=inquire("1=remeasure")
if status == 1
measure("Sphre PALPEUR REF",1)
endif
endif
//Upper Tolerance
if ID >29.99271 then
if status == 1
endif
endif
2. Error occurred after PCM function completed
OBJECT
a Zeiss.Calypso.OMGeoSphere ( id: 'Sphre PALPEUR REF("X-Valeur_Sphre PALPEUR REF")' )
ioSign->1 identifier->Sphre PALPEUR REF("X-Valeur_Sphre PALPEUR REF") flags->#(true) result->Dictionary (#technology -> #technology ) container->nil settings->nil comment-> icon->nil timestamp->nil radius->15.259054712304d location->nil definitions->nil
METHODSTACK
Unhandled exception: Message not understood: #vector
UndefinedObject(Object)>>doesNotUnderstand:
Zeiss.Calypso.OMGeoSphere(Zeiss.Calypso.OMGeoVector)>>vectorInput
Zeiss.Calypso.OMGeoSphere(Zeiss.Calypso.OMGeoVector)>>x
Zeiss.Calypso.OMCFabsolute>>actual:
Zeiss.Calypso.OMCFabsolute>>actual:point:
Zeiss.Calypso.OMCFabsolute(Zeiss.Calypso.OMControlFeature)>>valueWithPoint:actuals:nominals:CFs:
Zeiss.Calypso.OMCFabsolute>>valueWithPoint:actuals:nominals:CFs:
Zeiss.Calypso.OMCFabsolute(Zeiss.Calypso.OMControlFeature)>>value:nominals:CFs:
Zeiss.Calypso.OMMCFExecutor>>calculateResult
Zeiss.Calypso.OMMCFExecutor(Zeiss.Calypso.OMMExecutor)>>returnData2object
Zeiss.Calypso.OMMCFExecutor>>returnData2object
Zeiss.Calypso.OMMCFExecutor>>singleStepReally
Zeiss.Calypso.OMMCFExecutor class(Zeiss.Calypso.OMMExecutor class)>>singleStep:
Zeiss.Calypso.OMCFabsolute(Zeiss.Calypso.OMNamedObjectWithContainerInfo)>>singleStep
Zeiss.Calypso.OMMControlFeature(Zeiss.Calypso.OMMTaskWithReference)>>singleStep
optimized [] in Zeiss.Calypso.OMMTask>>executeDirectly
BlockClosure>>on:do:
Zeiss.Calypso.OMMControlFeature(Zeiss.Calypso.OMMTask)>>executeDirectly
Zeiss.Calypso.OMMControlFeature(Zeiss.Calypso.OMMTask)>>executeOneTimeWithProgressReport:
Zeiss.Calypso.OMMControlFeature(Zeiss.Calypso.OMMTask)>>executeWithProgressReport:
Zeiss.Calypso.OMMSetOfTasks(Zeiss.Calypso.OMOrderedList)>>executeOneTimeWithProgressReport:
Zeiss.Calypso.OMMSetOfTasks(Zeiss.Calypso.OMOrderedList)>>executeWithProgressReport:
Zeiss.Calypso.OMOrderedList>>executeOneTimeWithProgressReport:
optimized [] in [] in Zeiss.Calypso.OMMeasDefinition>>executeWith:with:
BlockClosure>>evaluate
Zeiss.Calypso.OMWindowsHolder class>>executeAndProfile:with:
optimized [] in Zeiss.Calypso.OMMeasDefinition>>executeWith:with:
BlockClosure>>valueNowOrOnUnwindDo:
Zeiss.Calypso.OMMeasDefinition>>executeSubPart:
Zeiss.Calypso.OMMeasDefinition>>executeActiveRunNoWatchDog:
Zeiss.Calypso.OMMeasDefinition>>executeActiveRunWith:
Zeiss.Calypso.OMMeasurement>>measureWith:
Zeiss.Calypso.OMUITestplanEditor(Zeiss.Calypso.OMUIEditor)>>executeInspection
optimized [] in [] in Zeiss.Calypso.OMUIEditor>>executeDefaultRun
BlockClosure>>valueOnUnwindDo:
optimized [] in Zeiss.Calypso.OMUIEditor>>executeDefaultRun
optimized [] in [] in [] in Zeiss.Basics.OMJobProcessor>>basicProcess:wait:
OMExceptionSetWithoutNotification(ExceptionSet)>>handle:do:
optimized [] in [] in Zeiss.Basics.OMJobProcessor>>basicProcess:wait:
optimized [] in Process class>>forBlock:priority:
#endOfMessage#
What's the problem?
Thanks for helping me solve the problem, Rick.
Please check the photo.
I use this program for calibration.
1. calibrate the master probe.
2. measure the master sphere with the master probe after calibration.
3. Calibrate the generic stylus.
4. After correction, measure the master sphere.
5. Compare the results with those of the sphere measured by the master probe.
