[De...] Posted August 19, 2024 Share Posted August 19, 2024 I have been asked to come up with some best practices and I am curious what your thoughts are on healing the cad model on initial import. I've worked in companies that did that as part of their process, and other companies which didn't do it at all, and a few in between. Is there guidance as to when to use the healing feature? I'm asking because others have asked my opinion, and I will confess I don't have enough knowledge to give a great answer. Link to comment https://qualityforum.zeiss.com/topic/5070-automatic-healing/ Share on other sites More sharing options...
[Ro...] Posted August 19, 2024 Share Posted August 19, 2024 I always heal, mainly due to my hatred of all my drilled holes being cut into 2 surfaces. But..... Several years ago I was working on a project, and there was a problem with a dimension I was capturing on a surface that could be verified with a height gage. I was showing the profile to be out of tol, but the thickness (which was the problem) was good measured on the granite. I measured the cad model and found that the distance to the surface should be X, and the print dim was different by a good amount. I went to engineering and asked them if the cad model was off to the print, and they said their master file was exactly where it should be. So I imported the file again, healed it and I noticed when I healed the model, something changed. I found that just selecting "Correct Boundary Curves" was fine, but one of the other functions, Simplification, Stitching, or Build Geometry caused my problem. So now I never click those buttons anymore.gfkhkhdw;kghdsfkjghdsfkjghdas.PNG Link to comment https://qualityforum.zeiss.com/topic/5070-automatic-healing/#findComment-17082 Share on other sites More sharing options...
[Cl...] Posted August 19, 2024 Share Posted August 19, 2024 I think most programmers would say to use healing all the time. I only use it when needed. If there is some obvious problem with the model. Ticking "Build Geometry" usually fixes any problem. Link to comment https://qualityforum.zeiss.com/topic/5070-automatic-healing/#findComment-17084 Share on other sites More sharing options...
[Mi...] Posted August 19, 2024 Share Posted August 19, 2024 I think the issue is poor explanations from Zeiss as to which selection does what.... I rarely do it. Link to comment https://qualityforum.zeiss.com/topic/5070-automatic-healing/#findComment-17086 Share on other sites More sharing options...
[Da...] Posted August 19, 2024 Share Posted August 19, 2024 I found this: http://www-isl.ece.arizona.edu/ACIS-doc ... /01CMP.PDF Link to comment https://qualityforum.zeiss.com/topic/5070-automatic-healing/#findComment-17088 Share on other sites More sharing options...
[Ca...] Posted August 19, 2024 Share Posted August 19, 2024 Here is an explanation from our Knowledge Base of what each option does for Automation Healing: https://portal.zeiss.com/knowledge-base?id=895194 Link to comment https://qualityforum.zeiss.com/topic/5070-automatic-healing/#findComment-17090 Share on other sites More sharing options...
