Curve Nominal Values Changing on Report
Trying to understand why the nominal values are changing on a line profile for a curve.
On the report called "cheeseblock demo program_9_pwr.pdf", the nominal values are X = 73.5001; Y = 32.0983; Z = -5.0393
The report called cheeseblock demo program_10_pwr.pdf, the nominal values are X = 73.4995; Y =32.0992; Z = -5.0410.
My assumption is calypso is reporting the actual and nominal value of the worst point in the line profile. Is this correct?
cheeseblock demo program_10_pwr.pdfcheeseblock demo program_9_pwr.pdf
Yes, the additional report info reports the nominal and actual values of the point with the worst deviation. Same thing occurs with surface profile as well.
