True Position of Tertiary Datum
I have an application where I have datum A (plane), datum B (center point of a hole) and then datum C (center point of another hole). My callout for datum C is 10±0.2mm diameter with a true pos. of 1.5(MMC)|A|B|. How do I properly check the true position of datum C in order to quality it back to A & B? How is this done before setting up the part alignment that is constrained by all three datums together?
Create a Position Characteristic (Position1). Convert it to a Best Fit Bore Pattern. Add Datum A and Datum B. Add your tolerance. Click Bore Pattern button. Click Select Elements button. Select Datum C feature. Click OK. In Best Fit section, un-check Translation checkbox. Select View Tolerance (with MMC/LMC of the references) Optional: Rename Best Fit1 (at top) to ABC. Click OK. Click OK to close Position window.
For characteristics that reference ABC, i.e. Position2, Select ABC from Datum reference frame dropdown menu, as shown below.
What if datum C & B are not in line with each other as far as Y, Z goes? Will your example for (Position1) still apply? My coordinates for C from datum B are 280.4 mm in "X", -118.7 mm in "Z" and C lies on a plane that is 587.2 mm in the "Y" axis.
I assume they drew all of the basic dimension off of the X/Y/Z Coordinate System, and they didn't make it where Datum C is inline with one of them. Like below.
If this is the case, you will still use Datum C as the Tertiary, but you will need to use the Rotate by distances (unless you want to work the Trig out yourself) function to square the Coordinate System back up to match the drawing.
  • 7 months later...
How do I then check the position of my tertiary datum to AB? Do I then use the method described above by Tom Oakes?
My initial response would be YES, but that may be a little biased...lol Are you having an issue with the instructions in my post? Are you stuck?
No, I understand your instructions. I just wasn't sure if it only applied if the tertiary datum was in-line with the secondary. Or if it would apply if my tertiary was offset to the secondary, but only after I have corrected my WCS as described by Richard Shomaker.
