PiWeb Reporting Plus license across machines?
We have one Zeiss CMM running Calypso, and are considering buying a T-SCAN hawk 2. If we purchased PiWeb Reporting Plus, would it work with both machines with one license? Or, would we need to purchase Plus for the CMM and ZEISS Inspect for the expanded reporting capability for the T-SCAN?
I would assume you would need an additional license and data is local to each machine. SBS and Enterprise versions of PiWeb would allow multiple devices under a single license and data is server/cloud based.
  • 4 months later...
Piweb Plus is per machine only and localized. So you would need an additional license for your T-Scan. if you want your machines to output to one database system, as Tom mentioned you will need the Entnerprise/SBS package instead.
