[Ro...] Posted August 12 Share Posted August 12 Hello guys, we have an old warning light that we turn on and off with a switch that indicates whether the CMM is running or not. I am in the process of automating this. I can control the lamp with the inspection_start and inspection_end files, but if there is a collision or other error, I can't catch it and the lamp stays on the "CMM running" state even though its not running. Is there any way to catch errors or collisions with PCM or other tools? Link to comment Share on other sites More sharing options...
[Ke...] Posted August 12 Share Posted August 12 I do not believe there is a way via pcm, collisions and errors trigger with highest priority and stop all processes before anything else would be able to send a message indicating the status has changed to the light. Link to comment Share on other sites More sharing options...
[Mi...] Posted August 12 Share Posted August 12 It's not used a lot, I've never actually seen anybody talk about it, but if you go to Extras>Settings>CMM> Light Signal Zeiss can natively control it to some degree, the picture shows your standard 3 level light tree. I'm also not going to be surprised if it's only in part of a larger, expensive, module but maybe it's not? Link to comment Share on other sites More sharing options...
[Er...] Posted August 12 Share Posted August 12 Was discussed several years ago. https://qualityforum.zeiss.com/topic/16784-if-then-on-an-error-messageredlight/?do=findComment&comment=93858 Link to comment Share on other sites More sharing options...
[Ro...] Posted August 13 Author Share Posted August 13 Thank you Eric, that file is my solution. I'll just read it with a pythonskript. Awesome! Link to comment Share on other sites More sharing options...
