add text line in report
Thanks.
I had tried that first and it didn't work. I was wondering if i have to change something in the printing output or make a custom report. I'm just printing to a default directory with Piweb type of standard protocol pdf report
Hello all,
Michael is correct in that the text elements need to be turned on explicitly. The main reason I am posting is to clarify that it doesn't work in all versions. I think this option was first available in Calypso 7.2. Here is a knowledge base article on it for future reference:
https://portal.zeiss.com/knowledge-base?id=1260636
In previous versions, Rick's solution is really the only way. In the particular context here, I think it might be a bit clearer anyway.
I hope that helps anyone else coming across this.
