[Se...] Posted July 18, 2024 Share Posted July 18, 2024 Hello, everyone ! I have a question. We used pcm to check the product location before measuring and then proceed with the measurement. 1. After setting the product due to operator error , The setting jig was not removed. 2.The product location was correct, but a collision occurred because the setting jig was not removed. 3. Here I am going to create random points on the setting jig. Measurement stops when any point is touched, If the touch does not work, I want to continue measuring. // Test piece measure("Z") if abs(getNominal("Z").z - getActual("Z").z) < 2 then measure("Y") if abs(getNominal("Y").y - getActual("Y").y) < 2 then measure("X") if abs(getNominal("X").x - getActual("X").x) < 2 then goto PieceOK endif endif endif This is an example of checking the current product location. If the touch does not work, proceed. Is coding possible? Thank You. Link to comment Share on other sites More sharing options...
[Ca...] Posted July 30, 2024 Share Posted July 30, 2024 Hello! Are you measuring a bore by chance? There's a built in function in CALYPSO to check to see if a bore is in place, and, if not, either stop or continue. A full description of that solution can be found here: https://portal.zeiss.com/knowledge-base?id=540011 Would that work for you? Link to comment Share on other sites More sharing options...
[Je...] Posted July 30, 2024 Share Posted July 30, 2024 I believe what you are looking for is "Material detection" and "Continue at missing probing". These can be set in the Measurement Plan Editor under "Probing". If you intend to allow the machine to continue without taking a point then you must enable "Continue at missing probing". This is a similar process to "Bore Missing" but works in the opposite fashion. A sample of what is possible is below. Note: This REQUIRES that "Continue at missing probing" is enabled for point features being called by PCM here. //--------------------------------------------Error Proofing--------------------------------------------------------------------------- //Error Proofing - skips if simulation - Material detection formula errors in simulation otherwise if getRecordHead("operator") == ("User") then //forces "User" to run errors proofing if getRecordHead("dmesn") <> ("000000") then //skips if simulation // verify REF sphere was removed measure("Point Ref Sphere PCM").z if getActual("Point Ref Sphere PCM").materialDetected == true then positionCMM(30,-30,-30,"Z","X","Y") message("REMOVE CAL SPHERE"+cr()+"Please Try Again") cncBreak() endif // check if part is there measure("Point1").y if getActual("Point1").materialDetected == false then positionCMM(30,-30,-30,"Z","X","Y") message("Part Not Present"+cr()+"Please Try Again") cncBreak() endif // check if fixture is clamped - 1 of measure("Point Clamp1").y if getActual("Point Clamp1").materialDetected == false then positionCMM(30,-30,-30,"Z","X","Y") message("Clamp not closed"+cr()+"Check Clamp"+cr()+"Please Try Again") cncBreak() endif //create plane from fixture test points. Recall points into plane to validate squareness of part to fixture if abs(deg(getActual("START Plane Recall").a1)) > 1.00 then positionCMM(30,-30,-30,"Z","X","Y") message("Part Not Fixtured Properly"+cr()+"Please Try Again") cncBreak() endif if abs(deg(getActual("START Plane Recall").a2)) > 1.00 then positionCMM(30,-30,-30,"Z","X","Y") message("Part Not Fixtured Properly"+cr()+"Please Try Again") cncBreak() endif endif endif //end error proofing checks section Link to comment Share on other sites More sharing options...
[Se...] Posted July 31, 2024 Author Share Posted July 31, 2024 Hello, Caitlin Thank you for answer. The address you gave me https://portal.zeiss.com/knowledge-base?id=540011 Page not found. The page you requested could not be found. Could you please check again? Link to comment Share on other sites More sharing options...
[Se...] Posted August 1, 2024 Author Share Posted August 1, 2024 Hello, Jeff Penrod I want to measure when I don't touch the product, and stop when I touch it. Link to comment Share on other sites More sharing options...
[Ca...] Posted August 5, 2024 Share Posted August 5, 2024 I've attached the Knowledge Base article as a PDF. See attachment.CALYPSO_ Continue at Missing Bore (Hole) - Carl Zeiss Industrial Quality Solutions, LLC.pdf Link to comment Share on other sites More sharing options...
[Se...] Posted August 6, 2024 Author Share Posted August 6, 2024 Hello, everyone ! Thanks for the info I solved this problem. Link to comment Share on other sites More sharing options...
