Drill Intersect Length
I am trying to measure a length from a drill intersect of a plane to the center axis of the part (please see attached). I have measured everything successfully but cannot reconcile the length (37.9). I have tried making a 3d line through the center of the part (via an OD cylinder) but the features turns purple (?). I went into Construction and made an Intersection of the drill cylinder and plane and it appears to put the x right where it should be. I must be missing something as in my head this should be easy. Thanks for the help!
How you made 3D line? It should be sufficent to use just cylinder if it's not short.
Then it should be easy - i am used to use caliper distance - just place this 3D line or cylinder with midpoint selection and that intersection of drilled hole and a plane. Then in "R" value is combination of X and Y value ( like in trigonometry ) - maybe you would need to use alignment with 3D line as +Z axis.
Yes, that worked perfectly! Thank you! I still don't understand why it couldn't create a 3d line out of a 18mm tall cylinder.....
It's already a 3d Line "technically".
But to answer your question is because to correctly build a 3d Line you need to use Recall and not Recall Feature Points. Since you measured Datum A as a Cylinder, you'd have to create Circles that you use Recall Feature Points for each Circle path inside of Datum A - then you could use Recall inside of your 3d Line to Recall the center of each individual Circle. That would have been a lot of extra steps for no real reason. 🙂
