Setting Path for Probe angle change
Hi all,
Quick one; I am using a RDS head measuring some shaft Ø's, both left and right side of the shaft (0 - 180 & 0 - -180) rotating probe angle in between.
How can I set a path so that once my probe as moved to its clearance plane X+ / X- (depending on which side of the shaft its measuring), it then clears the part before rotating the angle for the next feature?
Thanks in advance!
Jack
https://qualityforum.zeiss.com/topic/5166-setting-path-for-probe-angle-change/
