[Bo...] Posted November 2, 2021 Share Posted November 2, 2021 Hello I have a problem with direction of material + without changing default gom proprieties + or - Please make me understandin why where is material si - and viceversa Thank you Link to comment https://qualityforum.zeiss.com/topic/518-diferent-direction/ Share on other sites More sharing options...
[Bo...] Posted November 3, 2021 Author Share Posted November 3, 2021 Please sign in to view this quote. Link to comment https://qualityforum.zeiss.com/topic/518-diferent-direction/#findComment-1548 Share on other sites More sharing options...
[9b...] Posted November 3, 2021 Share Posted November 3, 2021 Dear Bogdan, You're analyzing a surface comparison, right? If yes then the following rule applies. Plus (+) means the actual (measured) mesh/data is above the CAD mesh. => means more material is there in reality than needed (compared to the reference mesh / CAD). Minus (-) means the actual (measured) mesh/data is below the CAD mesh. => means less material is there in reality than needed (compared to the reference mesh / CAD). Best regards, Matthias Best regards, Link to comment https://qualityforum.zeiss.com/topic/518-diferent-direction/#findComment-1549 Share on other sites More sharing options...
