O-Inspect Measure Volume Illumination
Good afternoon,
I'm using an O-Inspect 543 and would like to know how to turn on/off the light on the sensor head.
It can be done through the Calypso interface in the "stop light" dialog box, but was wondering if this can be achieved any other means(key sequence, from the pendant, programmable variable, etc.) Thanks.
You can also use the PCM commands measVolumeIlluminationOn() and measVolumeIlluminationOff(). There is also a key sequence on the joystick box (Shift-Lower return-something), but I don't remember it right now.
Via the Joystick Box:
Measuring Volume Illumination (If your O-Inspect is fitted with one, not all are)
ON: Return (Upper-half) + F4
OFF: Return (Upper-half) + F5
Laser Pointer
ON: Return (Upper-half) + F2
OFF: Return (Upper-half) + F3
