Report Headers and Parameters
I'm having a bit of trouble adding the selections from "select report header parameters" screen to our PiWeb report. I found (1) video on youtube from 2017, but it appears that some of the selections have changed since then. I'm also not very familiar with PiWeb as most of my time is spent in Calypso, but we really need to add the Workpiece Serial No to our reports. I attached a pic showing the selections I've made. The "Order" in the green box appears on the PiWeb report by default, I guess. They both appear at the start of a run, so I did at least one thing right 🤣
Can anyone walk me through how to add the Workpiece Serial No to our PiWeb reports?
Thanks in advance!
Hello Dylan,
This document from our knowledge base may help. The first is about setting up your own header field, which isn't necessary at this point, but the rest of it should walk through how to add it to PiWeb properly. I think about the only thing that it really skips is the fact that if you hover over the "?" column of the row you want, it should give you the code you need to enter into PiWeb to get it working, assuming you have bubble help on that is.
https://portal.zeiss.com/knowledge-base?id=454780 3037_4c3c4bf66dcc7c16d85346164ca4ef72.png
I hope you find this helpful.
  • 3 weeks later...
