[Ch...] Posted July 15, 2024 Share Posted July 15, 2024 Hi everyone, I have passed PCM class and am a fairly avid PCM user, however I'm stuck at a simple task that is not working for me. I would like to assign a variable for a Z height of a point, then Assign a tolerance (0.010") then assign a variable for Min tolerance = MYVAR-TOL and max tolerance : MYVAR+TOL, because this code will likely be use on multiple parts and simplifies things. Doing the following, by adding 2 VARs that have numbers seems to just combine them, for example this code //Get Part Nominal Z value PTZ=formatL((getNominal("Point FIND Z").z),0,5) message("Z Nom is : "+PTZ) // assign var to max limit MAXZ=getNominal("Point FIND Z").z+0.010 message(MAXZ) //adding variables doesnt seem to work here TOL=0.0100 MXZ=TOL+PTZ message(MXZ) Assuming the PTZ = 9.3000 The message MAXZ = correct value 9.400, the message for MXZ (when I add 2 variables) is 0.0109.300 or something similar. If I tried PTZ+TOL it would show 9.3000.010. However when I try simple math such as : VAR1=3 VAR2=4 SUM=VAR1+VAR2 message(SUM) This produces expected result and message = 7. Am I missing something here, or should I avoid adding VARiables ? ❓ Thank you ! Link to comment https://qualityforum.zeiss.com/topic/5282-variable-math-not-mathing/ Share on other sites More sharing options...
[An...] Posted July 15, 2024 Share Posted July 15, 2024 Hey Chris! The issue is data types! formatL / formatR / format return a string. The 2nd line, PTZ becomes a string. Which causes TOL to become a string when adding them together. It looks like when doing addition that involves a string, everything gets turned into a string. The number 9.3 becomes formatted to "9.300" The number 0.01 becomes "0.010" So "9.300" + "0.010" = "9.3000.010" Consider using round instead of format to keep the data type a number? If you have to display the number, maybe use format on the fly instead of assigning to a variable? PTZ = getNominal("Point FIND Z").z // or round(getNominal("Point FIND Z").z, 5) message("Z Nom is : " + formatL(PTZ, 0, 5)) Link to comment https://qualityforum.zeiss.com/topic/5282-variable-math-not-mathing/#findComment-18422 Share on other sites More sharing options...
[Ky...] Posted July 15, 2024 Share Posted July 15, 2024 Hello Chris, I think what is happening is the way you are defining PTZ is making it a string rather than a number. One way around it would be to define PTZ as "getNominal("Point FIND Z").z)" and then make another variable PTZString as "formatL(PTZ,0,5)". Alternatively I believe you can case the original PTZ as a number if you use "val(PTZ)" at that end part. I hope you find this useful. Link to comment https://qualityforum.zeiss.com/topic/5282-variable-math-not-mathing/#findComment-18424 Share on other sites More sharing options...
[Ch...] Posted July 15, 2024 Author Share Posted July 15, 2024 Please sign in to view this quote. Andrew, got it makes perfect sense. Thanks, Chris Link to comment https://qualityforum.zeiss.com/topic/5282-variable-math-not-mathing/#findComment-18426 Share on other sites More sharing options...
[Ch...] Posted July 15, 2024 Author Share Posted July 15, 2024 Please sign in to view this quote. Thanks guys, yes makes perfect sense now. Mondays I guess ... Link to comment https://qualityforum.zeiss.com/topic/5282-variable-math-not-mathing/#findComment-18428 Share on other sites More sharing options...
