Script to control Temperature parameters
Hello,
I'm looking at implementing a temperature check into our current production scripts. I would like to set the reference at 20 degrees +/-1 degrees , and set the system to abort the routine if a temperature is inputted higher or lower than the set parameters. I have found some items under the acquisition parameters, but this seems more to do with temperature change etc.
Thanks in advance
James.
Hello James,
this is already implemented in the software with the acquisition parameters. Do you really need to script this? In an automatic system like our Scanboxes the measurement can be aborted automatically if the temperature is out of the defined tolerance.
Regards,
Nanno
