Change Evaluation Standard DIN to AGMA
Hi,
How do i change the evaluation standard from DIN 33965 to AGMA?
I am changing it in the setup button but the results still show as DIN.
Thank You,
Nixon Uruchima
you want to go into each measurement task, such as pitch on the left side of the screen with .gear file open.
in there , there should be a tolerance tab, you can change from there.
