Can i get the unit of a characteristic as a string
Hi guys,
is there any way to get the unit of a characteristic?
Im looking for something like this:
getActual("test").actual.getunit
I think you can not change individual characteristic.
Changing angle units are for whole plan - stored in "inspset" file findable by "inAngleUnit"
You can make condition with help of therotecial element where you put 90° angle.
Report: 90,0000 -> degrees / 1,5708 -> rad / 90° 0' 0" -> deg. min. sec.
I could not find angle unit in pcm - maybe others can
I also do not see that you can set for individual unit.. 3239_77350a4b2622f4230f49576c88c42420.jpg
but I did test by changing the entire plan to 1)degrees 2)DegMinSec 3) radians
and the following returns the chosen units :
getNominal("Some Characteristic Name Here").lengthunit
result returns one of the following : #degrees, #DegMinSec, or # radians
Cheers.
