Creating line with no features
Hello Zeiss Community,
I have a print that requires an angle measurement from a center line on the X axis a bolt hole circle. I've created a 3d line in the Y axis using two bores but X axis has no features I can use. Any advice on how to approach this work be appreciated.
Thanks,
Simon
Thank you,
Can you point to me to any guides about theoretical features? I never used them and I haven't had much luck searching the knowledge base or calypso online help. I can create a 3d line and select "theoretical feature" but I don't understand how to define the length and ordination of the line.
here is a basic example, setup the base alignment to use the 3d line you originally created for your rotation. 6639_16507dc9d96bbf015144df76b14c506f.png
then setup theoretical 3D line, you can adjust its position with the nominal values and change the depth of the line to make it longer/shorter. also you may need to play around with the A1 X/Z / Y/Z so your line is sticking out in the correct direction in relation to your XYZ of your base alignment. 6639_ccd3248194ff366e62f1866187864d3a.png
