[Ch...] Posted June 13, 2024 Share Posted June 13, 2024 PCM wizards : Anyone know the instance Variable to get the tolerance (including bonus) of a position characteristic ? I can't even seem to get the upper or lower tolerance using : .lowTol, .lowerTolerance, .lowLimit, .lowerTol Is there any other system variable this is attributed to? In excel output the upper tolerance appears to be the tolerance with bonus, however on old custom report it goes in low tol column. Hopefully in 2024 PCM will be a bit more friendly/intuitive ... Thanks all !! Link to comment Share on other sites More sharing options...
[Mi...] Posted June 13, 2024 Share Posted June 13, 2024 Given Tolerance: getNominal("Position1").tolerance.upperTolerance Given Tolerance + Bonus getActual("Position1").tolerance.upperTolerance Link to comment Share on other sites More sharing options...
[Ch...] Posted June 13, 2024 Author Share Posted June 13, 2024 Thank you Michael, brilliant sir ! Man I wish we had more PCM access in Calypso. Cheers ! Link to comment Share on other sites More sharing options...
[Jü...] Posted June 14, 2024 Share Posted June 14, 2024 Hello, We work with this PCM command: getActual("DIN Position1").dmisotol Link to comment Share on other sites More sharing options...
[Ch...] Posted June 14, 2024 Author Share Posted June 14, 2024 Jurgen, Would you know if this is available for QDAS output ? Link to comment Share on other sites More sharing options...
[Jü...] Posted June 17, 2024 Share Posted June 17, 2024 Hello Chris, I don't know that. We use it in a result element. Link to comment Share on other sites More sharing options...
[Ka...] Posted June 24, 2024 Share Posted June 24, 2024 for Qdas use: #MMC/LMC K2112 22 F C:userlowertol K2113 22 F C:useruppertol Link to comment Share on other sites More sharing options...
[Jo...] Posted October 24 Share Posted October 24 Please sign in to view this quote. getMaxActual("Position1").tolerance.upperTolerance //Had to ad max otherwise, get error. For bore pattern! 1 Link to comment Share on other sites More sharing options...
