Report to file
Hi all, Using 7.6.1202, I have all my programs set up to automatically save the Piweb reports on our server, easy to set up, works like a charm but I have one program that for whatever reason will not output the report and I cannot figure out why. Path is correct, no gaps in the code and have the correct file ending. When its done running you see it execute and send to file but it never pops up in the folder, just goes somewhere into the abyss. I don't believe it's anything to do with windows permissions on that user as it won't even work from my offline stations. its selected to output to file location in both the definition of multiple report and within Resources>Results to file... Am I missing something dumb? Anyone have any ideas? All my other programs are set up identically, I'm at a loss for why its not working. Thanks as always, in advance!
PDF is checked! I can't figure out the snag, really weird. All my programs are set up like this and this is the only one that doesn't like it.
no, no symbols in the program name just underscores and dashes there is a total of 4 programs for this part, the other 3 run fine and output the results correctly, the 4th is the only one with the issue forcing operators to manually save.
