Circle on cone
Hello
I am measuring a inside circle on cone in Calypso 7.2.0 and sometimes it starts beside the hole and drags the probe in to the hole before it starts measure. I tried to change to outside measurement as a test but the it stops for collision when it reach the face.
It doesn't stop when I use inside.
Any ideas?
What's your retract distance?
Go into Measurement plan editor and select "Probing" then "Search distance before nominal position" and put a large number in there, say 0.100" or 0.200". That'll force the machine to start back a ways and slowly glide into probing position.
I will try the latest servicepack and se if it solves the problem.
The search distance didn´t help.
The strange thing is that if I change to circle it works, change back to circle on cone ..doesn't work.
Lets hope that the service pack do the magic,
Thanks for your tip
I would think the vectors are wrong.
If its an ID, the vectors should be toward the inside of the feature, this seems like they are pointing outside the feature.
