Bubbled Dwgs
Following the YouTube tutorial by R. Dean Odell on Making a bubble Print Report in Piweb, I have run into a road block.
I have followed everything, when I get to the bubbling and click on the Data Provider Tab, it is empty. I have not run the program, as I am waiting on fixturing to hold the part to measure as much in one shot as possible, and prove it out properly. Do I have to run the program before the Data Provider tab is populated, or is something missing?
That is correct. It populates data provider after execution. It will also show items that were there, but have been renamed or removed as well. So if one is in the list, it doesn't mean it is still there.. once you have data, you can preview inside the template. I have my bubbles conditionally formatted Red/Green depending on results
Thank you sir for the info.
That explains why there were items he could choose from that were not in the Characteristics list.
Doing the same as far as conditions.
