Measure at high temperatures
Good morning,
There is the air conditioner broken in the metrology room and at the moment there are 29°C. I know that is not correct measure with this temperature but my question is regarded the safety of the machine. I've a Contura, Is it dangerous to use it with this temperature? Could it cause some system problems?
Depends on which Contura Model we're talking about.
The current model 6206 can be operated at a temperature range of 17-35°C
The model is a Contura G3...
Edit. I found the manual and the range is the same. Thanks.
