[Th...] Posted June 13, 2024 Share Posted June 13, 2024 For a typical cylinder position callout with no projection, is it more appropriate to pick tolerance feature as center line or tolerance feature with ref length? Edit: ASME drawing2.PNG1.PNG Link to comment https://qualityforum.zeiss.com/topic/5440-typical-cylinder-position-option/ Share on other sites More sharing options...
[Ju...] Posted June 13, 2024 Share Posted June 13, 2024 For Position, I usually measure cylinders as circles, so there's less room for projection error. Link to comment https://qualityforum.zeiss.com/topic/5440-typical-cylinder-position-option/#findComment-19394 Share on other sites More sharing options...
[Mi...] Posted June 13, 2024 Share Posted June 13, 2024 That answer also depends if you're working on an ISO or ASME drawing Link to comment https://qualityforum.zeiss.com/topic/5440-typical-cylinder-position-option/#findComment-19396 Share on other sites More sharing options...
[Ch...] Posted June 14, 2024 Share Posted June 14, 2024 Here is a ZEISS Knowledge Base guide that goes into a little more detail on the subject matter. CALYPSO: Recorded Center Line vs. Reference Lengths: https://portal.zeiss.com/knowledge-base?id=2615475 Link to comment https://qualityforum.zeiss.com/topic/5440-typical-cylinder-position-option/#findComment-19398 Share on other sites More sharing options...
[DW...] Posted June 18, 2024 Share Posted June 18, 2024 Please sign in to view this quote. Great point. OP, you can also measure the cylinder using multiple circle paths, and then create an intersection of the cylinder with a plane. Calypso has no problem with true position of an intersection. Link to comment https://qualityforum.zeiss.com/topic/5440-typical-cylinder-position-option/#findComment-19400 Share on other sites More sharing options...
