[Aa...] Posted June 18 Share Posted June 18 Quick Question: If I Create a 3D Line with "Recall" and select two cylinders that are nominally coaxial, what will the 3D line "recall"? The midpoint of the cylinders' axes? The measured "zero" points of the features? Link to comment Share on other sites More sharing options...
[Da...] Posted June 18 Share Posted June 18 I'm not sure, but the midpoint of each cyl axis would make the most sense. So, knowing Calypso, it's probably not that ! 🤣 Link to comment Share on other sites More sharing options...
[Ab...] Posted June 18 Share Posted June 18 https://portal.zeiss.com/knowledge-base?id=1182601 Link to comment Share on other sites More sharing options...
[Cl...] Posted June 18 Share Posted June 18 I just tried it in planner, and it looks like it's from the mid-point of each cylinder. Link to comment Share on other sites More sharing options...
[DW...] Posted June 18 Share Posted June 18 Yes, its like when measuring a Cartesian distance.. its a centroid to centroid measurement. It may also be a good idea to project that 3d line to a parallel plane if you want to eliminate the a1/a2 angles created from your recalled 3d line. Link to comment Share on other sites More sharing options...
